MUST GO CLEARANCE~~ 3 Turbo Manifolds, Wastegate 38mm, D16z6 block/crank/pisonts/rods/oil pan/extra'
If you are going to give me an offer, DO NOT LOW BALL ME!!!! these are the lowest prices i will go, and are DAMN cheap...
My lose, your gain... all items must go... CLEARANCE SALE! lol If you would like to pick anything up, i'm i Mid/eastern Iowa.
I HAVE TO MOVE out of my dorm room to drive 1200 miles back home in 2 1/2 weeks, i need to get rid of this stuff NOW!!!
For Sale, i have alot of extra parts lying around:
Extra D16z6 Block. No head. Includes: Flywheel, alternator, timing belt, stock pistons/crank/rods/water pump/ oil pump/ strainer, pickup, and oil pan/ and starter. $50+shipping
D16z6 Intake Manifold with Throttle body/map sensor/tps/and all attatched sensors... $40+shipping
Stock D16z6 vtec fuel rail / Fuel pressure regulator / 240cc injectors: $20+shipping
3 ssac turbo manifolds: D16 mani's!
1-used, has slight crack on runner, very VERY MINOR... a little Tig weld will fix. It cracked because i had no flex pipe on my downpipe. $25+shipping
2-slightly used SSAC manifold/still shines... i No longer need it... 35$+shipping
3-Brand New SSAC manifold with gaskets and bolts... $70+shipping
I'm an SSAC sponsor car, he uses pics of my car on his ebay auctions, so i have alot of stuff lying around
38mm wastegate: 5.83psi spring
1- used 6 bolt pattern external wastegate with two bolt flange - silver - 15$+shipping ($115+ new)
I accept PayPal and will ship asap (cuz it's gotta go, i'm moving at the end of the semester!)
Vouches: i sell alot on homemadeturbo.com, and Turbod16.com. Also, i have a 55 feedback count on Ebay 100% positive.
owen_the_soyboy
Nov 6, 2004 06:35 PM
J.P.
Aug 19, 2004 01:59 PM
