Damn defi tach wont work
Old Apr 23, 2006 | 08:45 PM
deucedeuceEK's Avatar
Default Damn defi tach wont work
So I decided to throw in my defi tach today that I had sitting around. Last time I had it hooked up it worked perfect. But for some reason I can't get it to work. The needle lights up, the whole tach like half way lights up and the little lights on the box that set ur shift points light up. And whats wierd is the tach is only lit up win my lights are off. When I turn my lights on the tach lights go off(needle stays lit though). I have the power and neg hooked up from the stereo harness, the allumination put in the dash light fuze and the ignition on wire hooked up to the fat yellow wire comming out of the steering column.
This is the correct wire for the signal isnt it?
bad pic sorry. orange into the yellow stearing column wire
I think maybe the tach is jsut screwed up, how I dont know. Worked fine when I took it outta my old car. But for what ever reason the needle stays at 2k on or off. Any suggestions would be apreciated. Thanks.
Old Apr 24, 2006 | 08:58 AM
Default Re: Damn defi tach wont work (deucedeuceEK)
anyone?
Old Apr 24, 2006 | 09:53 AM
JDMorgan's Avatar
check voltage across it... tachs usually stay at the last rpm they were at when u turn them off.
Old Apr 24, 2006 | 11:04 AM
importdude2000's Avatar
thats ghetto wiring
Old Apr 24, 2006 | 01:33 PM
siblueg's Avatar
Default Re: (importdude2000)
use the right spot for your rpm signal, the correct one is by your clutch slave cly.
Old Apr 24, 2006 | 01:39 PM
EJ1 wilcox's Avatar
Default Re: (siblueg)
How the hell do you have that thing wired up?
The signal wire looks correct. Although I always get the signal from the cluster or ECU so I don't have to go through the firewall.
Old Apr 24, 2006 | 02:00 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (EJ1 wilcox)
Wow dude... that wiring is AWFUL!
Old Apr 24, 2006 | 04:23 PM
Default Re: (JDM_Ej)
thanks for the wiring comments lol. The previous owner had a ghetto alarm in the car so really all of that is his handy work. And really the pic makes it look more of a messs than it really is.
Deathcabforme
Audio / Security / Video
Jul 13, 2005 07:23 PM
Ratchback
Jun 30, 2005 08:46 PM
itsJDMyo
Apr 3, 2005 05:59 PM
ndogg
13
Sep 1, 2002 01:15 AM
