axles
Old Apr 23, 2006 | 06:13 PM
95_red_dc's Avatar
Default axles
i have a 91 crx with a b18b in it and i have the whole axle set which is driver, half shaft, and passenger axles from a 91 teg but the half shaft wont bolt up, so then i bought a 94 teg half shaft and it bolted up just fine, now can i still use the passenger axles and since the half shaft has 2 male ends on it what axle should i use for the drivers side axle should i use one from a 94 axle
Old Apr 23, 2006 | 06:59 PM
I_eat_Rice's Avatar
Default Re: axles (91cleancrxsi)
I have a 90 crx with a b16a1 in it and a s-1 tranny and im using 93 integra gsr axles on the drivers side and a 94 on the passenger, the 94 on the passenger was because i was told that for both sides but did not know my car had to have to males so tell me if you need any help mine took a week to get uot and finally got them out with an pittman ball joint puller modified to pit around the shaft of the axel, a propane blow torch and a very large hammer, and lots of jackstands and cinderblocks. Hope this helps you the trannys are both bseries so it should be the same.
Old Apr 23, 2006 | 09:18 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi &raquo;</TD></TR><TR><TD CLASS="quote">i have a 91 crx with a b18b in it and i have the whole axle set which is driver, half shaft, and passenger axles from a 91 teg but the half shaft wont bolt up, so then i bought a 94 teg half shaft and it bolted up just fine, now can i still use the passenger axles and since the half shaft has 2 male ends on it what axle should i use for the drivers side axle should i use one from a 94 axle </TD></TR></TABLE>
For driver side you need 94-01 integra axle,99-00si,del b16a3..For passenger side just use the 91 integra axle you have,,but any b-series axle will work..
Old Apr 24, 2006 | 06:50 AM
95_red_dc's Avatar
Default Re: axles (Mr.speaker)
bump
Old Apr 24, 2006 | 07:02 AM
YasRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">For driver side you need 94-01 integra axle,99-00si,del b16a3..For passenger side just use the 91 integra axle you have,,but any b-series axle will work..</TD></TR></TABLE>
SoHc94
Feb 9, 2007 06:00 PM
xH22xTEGx
Jan 12, 2006 06:48 AM
ACRProject
Mar 15, 2004 07:59 AM
Mr_CRX
Mar 14, 2004 04:03 AM
foursquarepunk04
Feb 3, 2004 08:42 PM
