brakes hard > soft > hard (yes I searched)
Old Apr 23, 2006 | 03:53 PM
Syndacate's Avatar
Default brakes hard > soft > hard (yes I searched)
YEah I couldn't really find anything in the archived content that really described what happend..
'95 EX disc front drum rear no ABS
my brakes are hard, pretty hard actually
doign about 70 deer ran accross the road, jammed on my brakes, all the wheels locked up and I stopped..
Started going again after they cleared everything felt fine, about 2 min later I was pulling into the sub roads that go to my house and the brakes felt soft as hell, I thought I blew a brake line or something...got back to my house all like "wtf" - put it in reverse, went back out, went up the road, brake pedal was rock hard again and it stayed that way..
I know everybody's going to be like "bleed the brakes" as that's the answer to anything with the word "brake" in it on HT, but I was j/w if somebody knows what exactly happend...I've never had this happen to me, all my cars had ABS, so I'm not sure, any help is thx
Like I said, it's fine now, I'm just trying to figure out wth happend...
Old Apr 23, 2006 | 03:55 PM
schardbody's Avatar
you just blew the seal in the M/C it will get worse and worse. one day it might be good, the next it wont. its called "bypassing", when it starts to annoy you just replace it.
Old Apr 23, 2006 | 03:57 PM
Syndacate's Avatar
wouldn't it leak brake fluid if I blew the seal on it?
Old Apr 23, 2006 | 04:00 PM
schardbody's Avatar
no, not always, but yes eventually. the seal is on the actual piston inside the M/C, when its bad the piston moves through the bore but lets some of the pressure past the seal, so eventually you will see a leak (if you pull the m/c away from the booster) but normally you wont see the leak, alot of times it will leak into the booster and eventually ruin the booster as well.
Old Apr 23, 2006 | 04:04 PM
Syndacate's Avatar
Default Re: (schardbody)
I Have to take the master cyl off to check it? What exactly am I looking for... I mean if the leak's small and it's dripping one drip here and there I'm not raelly going to notice it dripping...
Old Apr 23, 2006 | 05:13 PM
Syndacate's Avatar
Default Re: (Syndacate)
*bump
Old Apr 23, 2006 | 05:14 PM
schardbody's Avatar
you wont see a drip. if you unbolt the m/c 2 bolts holding it to the booster, look at the back of the m/c if its wet or damp its leaking.
Old Apr 23, 2006 | 05:15 PM
Bense's Avatar
Default Re: brakes hard > soft > hard (Syndacate)
soft then hard then soft too soon? Been searching for an answer?
I need to start fowarding you my emails in my junk email folder.
Old Apr 23, 2006 | 05:29 PM
Syndacate's Avatar
*sigh*
Thx for the real help schardbody, I'll have to check this out :-\
v8killaz
Nov 8, 2010 08:42 AM
Steven5210
Honda Civic (2006 - 2015)
Jun 25, 2006 12:57 PM
97dc2
May 14, 2006 08:23 PM
Jagan'92
Dec 20, 2003 02:22 PM
