91 teg rear disc conversion on my 91 civic si questions
Old Apr 23, 2006 | 09:16 AM
racingant's Avatar
Default 91 teg rear disc conversion on my 91 civic si questions
i going to put 91 teg rear disc on my 91 civic si. what i would like to to know is if i do that will it expletive up my rear wheel alighment and can i use my stock 91 civic lower control arms on the teg arms because the teg lower control arms are done
Old Apr 23, 2006 | 09:45 AM
gsxr1k05's Avatar
Default Re: 91 teg rear disc conversion on my 91 civic si questions (racingant)
how about you search the faq first
Old Apr 23, 2006 | 09:49 AM
CRX Toad's Avatar
Racingant ONLY USE THE CIVIC ARMS. And all the way in the front that the compensator arm off the trailing arm not off the body and you may not have to get an alignment but I would highly suggest getting an alignment anyways.
Also work from the rear of the car forward and that is how you will get the compensator off.
Basically your just going to unbolt everything of the TA don't take off any of the arms.
Old Apr 23, 2006 | 08:54 PM
racingant's Avatar
Default Re: 91 teg rear disc conversion on my 91 civic si questions (CRX Toad)
so if i use the arms from the teg it will not work
gnccracer18
Mar 24, 2008 06:27 PM
FSTVTEC
Jan 2, 2008 06:25 AM
bigsubs
May 10, 2007 03:48 PM
jokr78
Mar 21, 2005 12:03 PM
92hybridhhatch
Feb 7, 2003 09:46 AM
