obd2a engine harness on obd2b motor, will it be ok?
Old Apr 23, 2006 | 08:30 AM
oneforce's Avatar
Default obd2a engine harness on obd2b motor, will it be ok?
I have a 96 civic ex coupe. I just swapped in a b16a2 which is obd2b. I bought the obd2a to obd2b jumper harness. Now my question is will the engine harness from my d16y8 plug onto my b16a2. ? Will i need to modify my ex harness in any way? What will have to be done?
Old Apr 23, 2006 | 10:23 AM
oneforce's Avatar
Default Re: obd2a engine harness on obd2b motor, will it be ok? (oneforce)
anyone?
Old Apr 23, 2006 | 10:26 AM
urbanbrown's Avatar
you MAY have to extent some wires but you will use the harness that came with the car and i also recommend an obd2a to obd1 ecu jumper harness and a chipped p28 ecu
post up how it turns out!
Old Apr 24, 2006 | 09:25 AM
oneforce's Avatar
im begining the harness swap today, and by the look of things, ill have to extend the vtec wires and the primary o2 sensor. Im staying obd2 so i bought the obd2a to obd2b conversion harness, you guys know how cali is..But after i get it ref, i will most likely convert to obd1.
Old Apr 24, 2006 | 10:21 AM
bmoua's Avatar
nope...you need a b-series harness....
alexpr
Jun 6, 2010 03:40 AM
b18csedan
Apr 26, 2010 02:54 PM
jdm_crazed
Jan 22, 2010 08:53 AM
jdmekrobot
Mar 13, 2008 12:13 AM
D3U1LT
Jan 24, 2005 10:47 AM
