Will a DC2 steering wheel hub fit an 88 CRX Si?
Hey!
I have an OMP hub and wheel from my ITR, and I am hoping that I can use the same hub on the CRX. Does anyone know if you can swap one for the other? In the ITR, there was just a 19mm bolt holding the hub in, so I would think that if the CRX shared that bolt, and if the splines are the same, it would work. I just wanted to know for sure. Thanks!
The splines and bolts are the same - however the ring that allows the horn & cruise to work and turns off the indicator after a turn will not. I've got a Teg wheel in my sedan and I had to use the Civic ring & drill new holes for the indicator shut off pegs. (not the most technical description of the parts, but you get the idea...)
Eric
Eric
Thanks for the reply. I won't be needing a horn or turn signals anyway, since this is a SCCA ITA car. I just need the wheel to fit. If the splines and bolts are the same, I think I'm good to go. Thanks!
yes, it will fit fine. I took the momo hub and wheel off my ITR and put it on my 91 Si. Momo even lists the same part # for both hubs. ITR nor CRX has cruise anyway, so nothing is an issue.
purple98ek
Jul 7, 2007 02:28 PM
dutchman5
Feb 7, 2006 08:30 AM
