93 honda accord
Old Apr 23, 2006 | 07:39 AM
jojo69's Avatar
Default 93 honda accord
Hi all,
I have a 93 honda accord Ex, automatic.
Can you recommend a reliable, cheap diagnostic tool for it?
My check engine light goes on and off by itself?
thank you all
Old Apr 23, 2006 | 08:21 AM
accord-pro's Avatar
Default Re: 93 honda accord (jojo69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojo69 &raquo;</TD></TR><TR><TD CLASS="quote">Hi all,
thank you all</TD></TR></TABLE>
You do not need any special tools , just a paper clip.. you need to jump the service plug, it is a 2 wire blue plug located under the right side of the dash, below glove box. by the kick panel, ..it might be wrapped with blue tape,,,
Anyho, when you find it, jump the 2 wirs together, turn the key on , and cound the # of flashes in the instrument clustet..
a long flash means a 10 ,, a short flash means a 1 ,, So for example ,,,
1 long 6 shorts = 16 ,,Also computer sould store more than 1 code . so make sure you let if flash at least 2 times around ..,,right down the code ( s) and post it here ..
Old Apr 23, 2006 | 04:25 PM
jojo69's Avatar
Default Re: 93 honda accord (accord-pro)
I just want to thank you again for your help.
I did exactly what you told me:
Check engine light: was always flashing a long flash non stop. i counted over a 100 times.
ABS light:
4 short then 2 short
4 short then 8 short
Shifter D4
1 short
2 short
7 short
8 short
TheTix
Jul 3, 2017 07:11 AM
TheTix
Apr 20, 2017 12:25 AM
dfbdavid38
Jan 15, 2011 04:08 AM
istabrak
Oct 28, 2009 01:14 PM
emptx
Oct 5, 2009 04:27 PM
