mini me swap
Tap into the blue wire at the distributor or the blue wire at the back of the gauge cluster for the rpm signal,,run that wire to the signal input on the rpm switch..
then from the rpm switch run a wire to an automotive 5-way 30 amp relay,,then from the relay to the vtec solenoid wire..Just to let you know, doing this will do nothing for you,,You also have to add the fuel and timing for the vtec stage..
ivanson
17
Nov 20, 2005 10:02 AM
schwett
Jun 2, 2002 12:34 AM
