Fully built JDM D15b vtec vs. b16
which motor should i go for? how much power can i expect from the jdm D15b vtec compared to the b16 stock... i need a motor soon, since my car has 228,xxx miles on it...
thanks for looking
thanks for looking
i have a d15b vtec pulls pretty hard for a single cam, you can even hear and feel the vtec x-over... dont expect the power out of it like a b16 though... the d15b is a good reliable motor expecialy for the money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. »</TD></TR><TR><TD CLASS="quote">i have a d15b vtec pulls pretty hard for a single cam, you can even hear and feel the vtec x-over... dont expect the power out of it like a b16 though... the d15b is a good reliable motor expecialy for the money
what kind of mods do you have on the d15b? how much horses do you have?
When you say fully built D15b vtec,,what do you mean by that? Sleeves,forged internals,ported head,large cam,etc? and turbo or N/A ?
Stock the B16a engines usually produce around 140-155whp..Depending on alot of things..To get a Sohc vtec to get 150 whp will require high compression,ported head,larger camshaft,custom ecu,good header,,etc,etc..But a stock D15b vtec with boost can make and handle around 200-225 whp with good fuel management ..Also with the d15b vtec you'll have to convert to obd1 or hack up an obd0 mpfi dizzy to fit that head..
ya exactly lol like what he ^^^ said above, what do you mean by fully built? just the most expensive internals you can buy and put it in there? going N/a is expensive, trying to gain like 30-40 hp out of a sohc going N/A is expensive, yes it would probably beat a STOCK b16 but if your willing to dish out that much money, i would just go forced induction for like $1000 (plus putting it in), get an engine management system (hondata, uberdata) for like $3-500 (boost option) get it tuned (couple hundred an hour) and your done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">When you say fully built D15b vtec,,what do you mean by that? Sleeves,forged internals,ported head,large cam,etc? and turbo or N/A ?
well now that you have explained, i guess i will go sohc turbo. ill just pick up one and start parting together a turbo kit with the money i save, maybe even start buying some jdm front end pieces..
B16a is super quick, and if you are looking for super high revs go for it. I used to rep B series all day long, but i've had some pretty gnarley D series competition...weren't Turbo but built to hell....Imagine what a built T Dseries can do. But like they said check your forced induction and smog stuff. a lot easier to bar a b16 then it is a Turbo D series.
research research....
I loved my jdm d15b when i had it(92cx)and my friends thought it was pretty quick.There was one time when i had hit vtec and this guy came up to me giving me compliments and even asked if i had a bseries(xcrossover is very noticeable loud to)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">B16a is super quick,</TD></TR></TABLE>
That's it
I quit at life.
*gun to head pulls trigger*
That's it
I quit at life.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin »</TD></TR><TR><TD CLASS="quote">
That's it
I quit at life.
So quick it has like a zillion horsepower when it's in mad 3rd gear vtec...
*gun gets pointed at head and delivers a bullet to my brain at speed breaking speed*
That's it
I quit at life.
wow....in any case i meant in comparison to what he's got now. Maybe you should go work on your car instead of coming up with witty things to say on a forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">wow....in any case i meant in comparison to what he's got now. Maybe you should go work on your car instead of coming up with witty things to say on a forum.
Nah my cars faster then a b16 already so its like ******* crazy and ****
I did put in a new clutch yesterday but, thanks for playing.
i wish i had the money for a aftermarket clutch, i can feel my oem clutch slowly losing its grip just through gear engagement at stop to go.
and ya lmao, b16's are super quick? they run like high 14's stock and mid 14's with bolt ons, which is probably close to $3000 for the complete motor swap with the bolt ons, cuz ya cant forget that C0LD ÁIR INTAKE Y0!!
d15 vtecs are pretty quick for sohc's
i have had both a d16z6 and a jdm d15 vtec in the same car and the d15 pulled harder than the z6
you would have to get custom pistons for the d15 tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8 Sukkah »</TD></TR><TR><TD CLASS="quote">REALLY good info... thanks a lot guys, im thinking turbo now. Still have my turbo timer from my Talon
hell yes go sohc turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx »</TD></TR><TR><TD CLASS="quote">d15 vtecs are pretty quick for sohc's
you would have to get custom pistons for the d15 tho</TD></TR></TABLE>
what you mean by you need custom pistons for a d15? for like if you wanted to rebuild the block or what? you talking aftermarket pistons? ive heard of custom pistons for a d15 a couple of times, just confused by it.
</TD></TR></TABLE>hell yes go sohc turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Also with the d15b vtec you'll have to convert to obd1 or hack up an obd0 mpfi dizzy to fit that head..
</TD></TR></TABLE>Or, you do what I have done a hundred times. You take your MPFI dizzy and gut it and take the obd-1 dizzy and gut it and swap em over.
works like a charm.
works like a charm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8 Sukkah »</TD></TR><TR><TD CLASS="quote">what kind of mods do you have on the d15b? how much horses do you have?</TD></TR></TABLE>
its stock for now except for a i/h/e and a chip from phearable.net... the best mod so far was the chip with the p08 maps and no top speed limiter and some other goodies... i plan on running a 100 shot zex but im still deciding its a d/d
as for hp i would take a stab at 140 at the crank i could be wrong though... that chip worked miricles i swear
built d15b? good luck finding pistons, they are going to have to be custom made. Vitaras(which are lower compression than most aftermarket) stick out the block on the d15b. just so you know...
digitally_remastered
99
Jan 12, 2006 07:53 PM
1991EFBeater
May 13, 2004 07:29 PM
