Comptech; OEM ITR, and other quality parts.
<FONT SIZE="3">Just a few items for sale...
Comptech Test Pipe - 2 1/4" $85. + shipping
Comptech high flow racing CAT - 2 1'4" very low miles on this... It cost $369. I'll sell it for $250. + shipping
Comptech B pipe (from Type R cat-back; axle-back portion not available) $75. Local P/U only. LV, NV.
Comptech SS TIG welded header for ITR - 2 1/4" (HPC thermal barrier coating) The two thermal barrier coatings, plus the prep charge cost $260 (I have the receipt). The header cost $529, for a total of $789. Price lowered to $250 + shipping. This would be a great header for a lightly modified B16. If this is your setup, don't miss out on this deal!
Slight scrape on the far right tube at the bottom; that caused a very small flat spot. This happened before the thermal coating was applied.
There is some minor damage to the thermal coating on the second tube from the bottom. This does NOT impair the thermal coating.
Comptech Racing ECU - This is a Comptech chipped OBD 2 1998 ITR ECU This cost over $400. from Comptech. Price dropped to $200. + Shipping
Acura OEM ITR 22mm rear anti-sway bar $40. + shipping ...you supply the end links.
B&M Racing short shift kit for 94-97 Accord/CL, new in package Price lowered to $25. + shipping
CG LOCK Seat belt locking device $15. + shipping
Hondata S200 w/data logging, w/o boost; and OBD 1 ECU w/ ZIF socket are
available now. $300. for both.
OEM ITR front strut tower bar $60 + shipping.
Thanks for looking...
</FONT>
Modified by Tomcat at 12:06 AM 4/23/2006
</FONT>Modified by Tomcat at 12:06 AM 4/23/2006
It doesn't turn down, it turns to the side. I believe this was OEM fitment, since the axle-back piece was available separately from Comptech.
Finally, JDM 4-1/Renault Cat/Hytech Exhaust Installed! Old Setups: Comptech 4-2-1, Comptech/OEM Exha
jomama
Nov 15, 2007 07:28 AM
Tomcat
Mar 16, 2006 06:21 AM
TypeRdude
Feb 10, 2003 07:23 PM
