Help. Could this be bad?
Old Apr 22, 2006 | 04:34 PM
9hatch6's Avatar
Default Help. Could this be bad?
I got alot of water coming from the exhaust that just leaks out and it comes out black from the exhaust. But i dont know if its just condensation. it does it everytime i start the car. i dont drive it at all still a project car. i start it maybe 2-3 times a week. could there be water in the cylinders?
Old Apr 22, 2006 | 04:42 PM
red91sit's Avatar
Default Re: Help. Could this be bad? (9hatch6)
Lol
Ever seen a car with out water coming out the exhaust? those are the ones that got problems (usually a hole in the ehxuast closer to the engine so you can't see the water coming out)
Old Apr 22, 2006 | 05:32 PM
9hatch6's Avatar
Default Re: Help. Could this be bad? (red91sit)
so is this normal? how would i know if i have water in my motor?
Old Apr 22, 2006 | 05:44 PM
1995Ex_Sedan's Avatar
Its normal.
Old Apr 22, 2006 | 05:50 PM
primojoe20's Avatar
i bi-product of combustion is water so i wouldnt worry about that however the black smoke is because your are running rich although it probly wont help i would retard your distributor a little bit or if you have an adjustable cam gear then retard that other than that check your o2 sensors
Old Apr 22, 2006 | 06:12 PM
9hatch6's Avatar
Default Re: Help. Could this be bad? (primojoe20)
thanks fellas
Sean @ ESG's Avatar
just condensation...dont worry unless it looks like a ragin fire hose of water
PPWLUDE
Mar 30, 2011 10:31 PM
Grenade2k7
Aug 14, 2007 01:11 PM
mk2
Jan 5, 2005 11:26 PM
Doubledeala
Oct 31, 2004 10:50 AM
Jorsher
Oct 22, 2004 02:54 PM
