FS: Chipped P28 ECU
Chipped P28 ECU
5300 VTEC
9100 revlimiter
$250 shipped
This program is ideal for DOHC VTEC B-series motors with single runner intake manifold (B16/B17/ITR intake manifold). It will yield substantial gains in the midrange as well up top and down low in the RPM range.
I run the same exact program on my '98 ITR. I would not sell something if I don't believe in it.
Dozens of other Honda-Tech members are running my ECU and are very pleased with the results.
Email me if you are interested in purchasing an ECU.
I also make OBD2 to OBD1 ECU conversion harnesses to allow this ECU to plug into '96-'01 Hondas and Acuras. It is a plug and play install.
-kenji
[Modified by kenji, 7:00 AM 4/8/2002]
5300 VTEC
9100 revlimiter
$250 shipped
-kenji
I have always preached the praises of kenji's work - it is top notch.
I first ran one of his jumper harnesses to run a JDM P73 ECU for my Type R swap in my 1992 Civic, and his harness is far nicer than that of Skunk2, etc. He uses O.E color-coded wiring, and he even included instructions on how to wire up the extra OBDII sensors if I needed to.
I then ditched the JDM P73 and decided to run a kenji-spec P28 for my B18C5 and I am totally impressed.
175whp and 123ft/lb. torque on a B18C5 with JUST his ECU and an intake and exhuast. Stock exhuast manifold, NO tuning!
Car pulls awesome and has a perfect idle. I can't ask for anything more.
If you have a Type R swap or a B18C1 built to ITR specs, or you have a nicely done B16A I would get this ECU.
hey kenji is it possible to just buy a chip off of you, i have a chipped p28 so and it has a jumper so that i can put other chips in, i would love to try your chip out, im running a b18c1 with jdm itr cams, springsk, retainers, port and polish head, milled, aem cam gears, skunk2 im, aem short ram, dc 4-1, 2.5 piping, test pipe, hyper clutch. what program do you reccomend for my setup, i currently have the mugen spec chip but would like to try out another chip
[Modified by Jdmb18c, 9:57 PM 4/8/2002]
Please email me with all of your questions. Thanks.
I will run a special for the next week. If you go to http://www.threebrain.com/songs/schoolbus.html and tell me what is the third animal that the schoolbus runs over I will sell you one of my chipped P28 ECUs for $215 shipped. No core charge. This week only. You must place and pay for your order by April 13, 2002. Good luck.
-kenji
[Modified by kenji, 6:34 PM 4/8/2002]
[Modified by kenji, 6:37 PM 4/8/2002]
-kenji
