Simple motor build: 210whp/134tq
With all the recent posts regarding wild builds, 2.0L's, Kseries...etc, I figured I would post up what a good combination of parts can do to a healthy ITR motor.
Link to the post in all-motor forum:
LINK
LINK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">Cool beans Marshal. Is this to show the viewers that performance can be had for minimal money and effort?</TD></TR></TABLE>
This is by no means a budget build, the header alone is $1200, but then again, you get what you pay for in this situation.
When all said and done, the customer probably spent under $2,500, with minimal install effort, cams and boltons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie »</TD></TR><TR><TD CLASS="quote">What type of Dyno?</TD></TR></TABLE>
DynoJet 248C
SAE numbers are 207/130
DynoJet 248C
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">
I wouldn't say budget build. But this shows to get good hp, a relatively small amount of money is required to get there, where as most of us go all out and spend three to four times that amount.
Who's Type-R is this?
I'd also like to add that how well your tune is, is relative to how well those simple add-ons are going to work for the motor. That dyno plot shows that a good tune means darn near everything.
RM cams does it again!!!
those are some sick numbers from a stock bottom end
What compression ratio does the motor have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead »</TD></TR><TR><TD CLASS="quote">it's been asked a few times already, but what induction was used?</TD></TR></TABLE>
Honestly seems like one of those freak motors though. Most other bolton+cam+tune combos with excellent quality parts (not including vavlesprings and retainers) would usually yield around 195 tops? These cams actually net over 10 more?
Updated the all-motor thread, but to answer the questions;
Intake - Password JDM CF intake (J's copy)
Motor - JDM ITR
Injectors - Don't know, enough to tune AFR's properly
Fuel pump - Stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose »</TD></TR><TR><TD CLASS="quote">Honestly seems like one of those freak motors though. Most other bolton+cam+tune combos with excellent quality parts (not including vavlesprings and retainers) would usually yield around 195 tops? These cams actually net over 10 more?</TD></TR></TABLE>
There are two types of motors, healthy and unhealthy. If a motor was broken in improperly, has low compression or leakdown out of spec, it will not make its potential power output. I think the main reason you don't see many 200whp USDM ITR's with boltons is most ITR's were broken in using the 'babying' method. I know there are a few USDM ITR motors making mid 190's on stock ITR cams, George Knighton's old motor is an example.
IMHO this build is completely reproducable. The M22X is a very good cam for compression between 10.5 and 11.5:1. The DTR header is a very good piece, with the same design header we dyno'd 13whp more peak, with a fat powerband over a DC JDM 4-1 on a JDM GSR motor, we would expect to see even more gains if a 1.8L header of DTR's new design was used.
Modified by 92TypeR at 7:36 AM 4/24/2006
Motor - JDM ITR
Fuel pump - Stock
Well I hadn't looked into the RM cams simply because they were relatively new when compared to other b-series cams. However, this is the type of stuff that brings a cam up to proven status in my mind
So if you dont use a header of the same design, your saying the peak numbers will be about 10-13whp less? So with cai, dc header, RM cams, tuned, it would make around 197 whp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR99 »</TD></TR><TR><TD CLASS="quote">So if you dont use a header of the same design, your saying the peak numbers will be about 10-13whp less? So with cai, dc header, RM cams, tuned, it would make around 197 whp?</TD></TR></TABLE>
Withholding all other variables, yes.
