b16 HEAD 400$$ with extras/Built Ls block (9:1 comp) 1000/ TRANNY/AXLES/EVERYTHING DIRT CHEAP!!!!! I
Old Apr 22, 2006 | 11:15 AM
hotimportcrx's Avatar
Default b16 HEAD 400$$ with extras/Built Ls block (9:1 comp) 1000/ TRANNY/AXLES/EVERYTHING DIRT CHEAP!!!!! I
B16 Vtec Head SOLD
Gsr Tranny 300.00 (Grinds at high rpm) WILL NOT GO ANY LOWER B/C ITS STILL GOOD IN TRAFFIC (Comes with starter and speed sensor). SOLD .
Del SOl Dohc Vtec SHift LInkage 75$ with energy bushings
Gsr Axles WIth Jackshaft SOLD
GSR Rear L Bracket SOLD
Gsr Driver Mount ANd Rear MOunt with INSERTS SOLD
AUto-MAnual Eg Tranny MOunt SOLD
P28 CHipped ECU SOLD
Ls Block
Scat H Beam Rods with Arp Rod bolts
Mahle 9:1 Compression Pistons
Mahle Rings
OEm Main Bearing
Oem Rod Bearing
Unorthadox Racing Crank Pulley
Micropolished Crank
New oil pan Gasket
External Oil line and fitting for ls vtec
b16 Vtec water pump
B16 vtec oil pump
GSR Arp Headstuds
PASSED compression test
SOLD
Also
Del sol Dual Core Radiator...with fan and hoses...SOLD
Del sol Hood SOLD
Del sol random interior pieces i have b/0
Black Acura Integra Cd Player With COde SOLD
Del sol Momo Hub 45$
Momo Steering wheel (silver/black) (little beat up) 40$
Together 65$
Modified by hotimportcrx at 12:52 PM 4/23/2006
Modified by hotimportcrx at 7:53 PM 4/24/2006
Modified by hotimportcrx at 7:54 PM 4/24/2006
Modified by hotimportcrx at 5:21 PM 4/25/2006
Modified by hotimportcrx at 5:12 PM 5/4/2006
Modified by hotimportcrx at 5:13 PM 5/4/2006
Modified by hotimportcrx at 1:20 PM 5/7/2006
Modified by hotimportcrx at 10:30 PM 5/14/2006
Old Apr 23, 2006 | 08:52 AM
Default Re: b16 HEAD 400$$ with extras/Built Ls block (9:1 comp) 1000/ TRANNY/AXLES/EVERYTHING DIRT CHEAP!!!
bump
Old Apr 24, 2006 | 08:08 PM
hybridpatient95's Avatar
eyjrj up
Old May 4, 2006 | 01:13 PM
Default Re: (hybridpatient95)
BUMP!
Old May 4, 2006 | 01:55 PM
Doh!'s Avatar
I could run that LS block without a vtec head if I capped off the extra oil fitting correct?
Old May 4, 2006 | 05:19 PM
Default Re: (Doh!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doh! &raquo;</TD></TR><TR><TD CLASS="quote">I could run that LS block without a vtec head if I capped off the extra oil fitting correct?</TD></TR></TABLE>
yes sir.. bump..
Old May 4, 2006 | 05:30 PM
yup
Old May 4, 2006 | 06:08 PM
high_revs's Avatar
bump for mah kneegro...
Old May 5, 2006 | 03:44 AM
pkel32's Avatar
do you have any del sol exterior parts that survive the wreck?
Old May 5, 2006 | 09:59 AM
what you lookin for?
Old May 7, 2006 | 09:20 AM
BUMP! Someone BUY MY BLOCK! i cant believe its still for sale
Old May 7, 2006 | 09:28 AM
SONIC BOOM's Avatar
Default Re: (hotimportcrx)
pmd
Old May 7, 2006 | 04:29 PM
high_revs's Avatar
up yo
SASi
Aug 5, 2010 08:57 AM
FLOSS
Nov 11, 2009 12:25 PM
95dcGSR
Feb 5, 2008 05:58 AM
Ryan111987
Aug 17, 2006 09:16 PM
