B18C1 Block, B16 head, black smoke PLEASE help!
Old Apr 22, 2006 | 08:09 AM
lojackgsr's Avatar
Default B18C1 Block, B16 head, black smoke PLEASE help!
K I have a 00 si with a b18c1 block and pr3-3 b16 head, running on P2T ecu... dc 4-1 header, intake and thats it. The car blows black smoke when I hit vtec or get on it, not horribly, but it does and it has really started to bother me just cuz i know people are seeing it... the car hesitates and acts odd in vtec... like i'll hit vtec and it will kind of be studdering or something... inside the exhaust is lined with black silt and obviously inside the header is also thick with black carbon / silt buildup... is the car running rich? timing ? what could it be, any help would rly be appreciated
On a sidenote: I have been ocasionally getting code 61 which is for primary O2 sensor slow, do you guys think this is the cause ? I know I need to replace it, so no one needs to tell me that but could this make the car run rich or blow black smoke?
Also I ocasionally smell the fumes of gas... This all could be pointing to one problem that im just not seeing or something help me out someone!
Old Apr 22, 2006 | 09:52 AM
OMG B16's Avatar
Default Re: B18C1 Block, B16 head, black smoke PLEASE help! (lojackgsr)
Fix your CEL's and your problem will most likely go away.
Old Apr 22, 2006 | 10:32 AM
lojackgsr's Avatar
Really, just for O2 sensor ? It comes on ocassionally like once every 2-3 weeks ... I've had O2 sensors go bad before on other bseries motors but it's never blown black smoke...
Old Apr 22, 2006 | 11:30 AM
projectTeG's Avatar
Default Re: (lojackgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lojackgsr &raquo;</TD></TR><TR><TD CLASS="quote">Really, just for O2 sensor ? It comes on ocassionally like once every 2-3 weeks ... I've had O2 sensors go bad before on other bseries motors but it's never blown black smoke... </TD></TR></TABLE>
yes seeing that the o2 sensor tells the ecu to cut or add fuel
Old Apr 22, 2006 | 07:12 PM
lojackgsr's Avatar
I just got off the phone with a technician at honda that told me the O2 sensor would have absolutely nothing to do with smoking ....
Old Apr 22, 2006 | 07:28 PM
projectTeG's Avatar
check you timing, but he is wrong smoking(running rich) can be caused by a faulty o2 sensor. what does the smoke smell like? in a circustances you should actually be running lean since your running on a 1.6 map instead of a 1.8 map
Old Apr 23, 2006 | 12:12 AM
2SlowDC's Avatar
fix codes then get tuned
Old Apr 25, 2006 | 05:43 PM
Jason.H.'s Avatar
Default Re: (2SlowJr.)
who ever u talked to at honda is a damned retard. if the o2 sensor cant read right then it adds more fuel and runs rich which blows out unburned fuel (black smoke) fix ur cel. if something is wrong then fix it.
Old Apr 25, 2006 | 09:28 PM
projectTeG's Avatar
Default Re: (DAPek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAPek9 &raquo;</TD></TR><TR><TD CLASS="quote">who ever u talked to at honda is a damned retard. if the o2 sensor cant read right then it adds more fuel and runs rich which blows out unburned fuel (black smoke) fix ur cel. if something is wrong then fix it. </TD></TR></TABLE>
DC2GSR808
Jul 3, 2014 06:35 PM
cam003
Aug 5, 2007 10:34 AM
Seraph
Nov 11, 2006 05:27 AM
lojackgsr
Apr 24, 2006 04:14 AM
kornerk12
Mar 19, 2006 05:26 PM
