Suspension & Brakes Theory, alignment, spring rates....
EK Hatch Swaybar Installation questions
Old Apr 22, 2006 | 01:35 AM
sifoo's Avatar
Default EK Hatch Rear Swaybar Installation questions
Hi All,
I want to order the ASR subframe kit so that I can install my DC2R rear sway on my EK hatch.
Can anyone tell me if I can use the existing D-brackets off my EK (I have an B16A EK4 - prob equivalent to your Si coupe over there) with the D-bushings off the DC2R rear sway bar?
Or do I have to order brand new D-brackets from the Integra Type R?
Thanks a lot
Modified by sifoo at 3:10 AM 4/22/2006
Old Apr 22, 2006 | 08:18 AM
JDMFreak's Avatar
Default Re: EK Hatch Rear Swaybar Installation questions (sifoo)
if you buy it from ASR, dont it come with all the hardware? ... i would assumed that you buy d-brackets from a 99-00 Civic Si good luck bro
Old Apr 22, 2006 | 05:06 PM
sifoo's Avatar
Default Re: EK Hatch Rear Swaybar Installation questions (JDMFreak)
No the ASR kit does not have D-brackets or bushings.
So your saying the D-brackets should fit BOTH original 15mm bushings and 22mm (type R) bushings???
Old Apr 24, 2006 | 03:15 PM
JDMFreak's Avatar
here is a link that mention about the d-brackets, but i think with the kit you dont need the d-bracket...maybe that why it is not provided in the "kit"...why dont you give them a call and ask for sure.
AOL Instant Messenger (AIM):
+ Charleston: COng825810
+ Chris: Beretta627
http://hybrid2.honda-perf.org/tech/ITRon5G.html
ps. judging by there instructions...you dont need one...
http://www.a-spec-racing.com/instructions.php
Old Apr 24, 2006 | 06:45 PM
sirg-vtec's Avatar
I believe you would have to order new D brackets for a type r.
Old Apr 25, 2006 | 05:17 PM
Wonk Unit's Avatar
Default Re: EK Hatch Rear Swaybar Installation questions (sirg-vtec)
where did you get your ASR kit?? and for how much?
Old Apr 28, 2006 | 04:11 PM
JDMFreak's Avatar
Default Re: EK Hatch Rear Swaybar Installation questions (Wonk Unit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wonk Unit &raquo;</TD></TR><TR><TD CLASS="quote">where did you get your ASR kit?? and for how much?</TD></TR></TABLE>
$340
damnecheck
Jul 5, 2005 03:40 PM
CptCorN
39
Oct 13, 2002 01:53 PM
JOHN WAYNE
Oct 3, 2002 08:49 PM
