Towing with Honda Accord
Old Apr 21, 2006 | 11:55 PM
JohanP's Avatar
Default Towing with Honda Accord
Can I safely tow 2,000 lb with a 2005 Accord 4 cyl, manual transmission? As far as I know the manual says I can only tow 1,000 lb, however I cannot understand why the rating is so low. In Europe most people tow around 2-3000 lb travel trailers with Accords, Camry's, Passat's, etc. And they usually only have 1.8-2 litre engines. Why doe we need big SUV's or trucks to tow the same trailer in North America? I would truly appreciate if someone can enlighten me on this issue. I don;t really care if it voids the warranty, I am just curious if it is safe, or not, and whether a European Honda Accord (sold here as the Acura TSX) is all that different.
I have just been able to verify that in Europe the Accord is allowed to tow 1,500 kg - around 3,500 lb with the standard 2.0 litre, 155 hp engine.
Modified by JohanP at 1:20 AM 4/22/2006
Old Apr 22, 2006 | 01:20 AM
iam7head's Avatar
Default Re: Towing with Honda Accord (JohanP)
double post batman
Old Apr 22, 2006 | 02:27 AM
YeuEmMaiMai's Avatar
this one is from another country. Given the weight of the car, I would NEVER TOW 3500lbs that is more than what the accord weighs. Honda would not tell you that it is OK to tow more than a certain percentage of a cars weight.
BTW I think their towing weight is wrong
they list a tounge weight of 75Kg (165lbs) and that is supposed to be 20% of the trailer weight. (based on us accord specs)
Your accord only weighs in at an average of 1400kg so again I think the number is towing in lbs not Kg. I believe that the safe towing weight of your car is somewhere around 460kg (1000lbs) and that would be right for a car that tips in at about 3100 lbs
Since the Acura TSX is the same car I looked up the towing capacity and it is 1000lbs
There is no way I can believe that the brakes on the euro accord (acura TSX) can safely stop 6000+lbs of car........not to mention the clutch in the manual trans being able to handle it....
Modified by YeuEmMaiMai at 5:41 AM 4/22/2006
Old Apr 22, 2006 | 10:08 AM
JohanP's Avatar
Default Re: Towing with Honda Accord (YeuEmMaiMai)
The tow rating og 1500 KG, not LB is from the official Honda Accord brochure, I downloaded the brochure from Honda Denmark. The Acura TSX is the exact same car as the Honda Accord, except that the model imported to North America has around 200hp.
I grew up in Europe, I used to tow a 2500 LB travel trailer all around Europe in a 1983 Toyota Camry with 1.8 litre engine, 90 hp, no problems with the clutch or anything else for that matter. I should be said though that those trailers in Europe are fitted with brakes.
Europeans dont have big trucks or SUV's so they tow with what they have, which is 4 cyl. sedan's.
Old Apr 22, 2006 | 03:39 PM
Don't say you wern't warned when your car dies due to a toasted clutch........I know what the specs said I read them and that is why I said I THINK THEY ARE WRONG......
Floos
Sep 4, 2018 10:51 AM
nlopez
Sep 11, 2017 12:42 PM
ssmig
Jun 11, 2017 12:06 PM
wealth20xx
May 3, 2017 01:36 AM
