ES Trail arm set poly
got my master kit in, so at same time put in trail arm kit.
Followed instructions pressed the big bush out and metal ring, however the new bush is too small.
Now by looking at things, i am thinking unllike the rest of the kit and instructions that you need to actually keep the metal ring in.
any other come across this. Car is a prelude.
Grind out the old bushing, press in the new one, put in the center bar and bolt it all up. Don't forget to lube the bushing well, as they will start making noise within a year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy »</TD></TR><TR><TD CLASS="quote"> you need to actually keep the metal ring in.
that is correct. cut, burn or wire bush the old rubber out of the shell and press it back in.
ef9robert
13
Feb 28, 2007 02:14 PM
94vtirozguy
Apr 20, 2006 05:37 PM
92integraVTECgsr
Suspension & Brakes
Jan 12, 2006 08:01 AM
