dumb question, but can anyone describe where to look for the clutch slave cylinder?
Old Apr 21, 2006 | 08:03 PM
bluskye's Avatar
Default dumb question, but can anyone describe where to look for the clutch slave cylinder?
1994 Honda Accord Ex
I bled my brake fluid for the brake system. I cant seem to find the clutch slave cylinder to bleed the clutch system. I crawled under the car, but i cant seem to find it as easily as my bmw.... can someone explain where to look? I have seen all the diagrams and such, but I cant relate it to where to look on the car... is it located on top of the tranny, or should it be visible under the car?
Thanks in advance.
PS, and yes, it's probably overdue since I cant account for the last clutch bleed since I got the car about 6 months ago.
Old Apr 21, 2006 | 08:18 PM
gianinline's Avatar
Default Re: dumb question, but can anyone describe where to look for the clutch slave cylinder? (bluskye)
It's attached to your tranny.... it has a little rubber piece, and you can actually play it "in" and "out". It should be close to the lower radiator hose, right next to your starter.
Old Apr 21, 2006 | 08:22 PM
fw190bvi's Avatar
Default Re: dumb question, but can anyone describe where to look for the clutch slave cylinder? (gianinline)
its RIGHT next to the starter. you'll see the fitting attached to it, and, as said before, there is a rubber-accordian shaped boot
Old Apr 21, 2006 | 10:02 PM
bluskye's Avatar
Default Re: dumb question, but can anyone describe where to look for the clutch slave cylinder? (Teh FW)
Thanks alot guys. I guess looking for it under the car was wrong. I thought I saw it next to the starter....
Thanks again.
doughboi904
Dec 9, 2011 12:43 PM
curtie94
Sep 9, 2011 05:30 PM
Ender.
11
Apr 4, 2005 11:27 AM
GSlowR
Sep 30, 2003 01:08 PM
SpooN Man
Aug 26, 2002 11:55 AM
