92 accord ex leaking coolant & runny Hot, HELP!!!
I dunno anything about accords, but its a 2.2L EX and its leaking coolant from underneath my alternator, is that my water pump?
Have it checked immediately by a mechanic.
It Sounds very much like your water pump leaking either from the gasket or the vent hole in the water pump which in either case would be need of replacement as well as your timing belts while you're in there along with the tensioners/seals. Happened to my 1992 Accord LX in 11/05 exactly like you described.
You better do this as soon as possible as you can have overheating problems and these cars don't take well to that with more heavy repair bills to result.
what is the milage on the car? might want to do the t-belt at the same time as the water pump if your belt is due.......
patoloco008
Aug 29, 2013 11:42 AM
