did a compression test...
Old Apr 21, 2006 | 11:24 AM
gisserhatch's Avatar
Default did a compression test...
150 psi in all all four cylinders cant be normal...stock gsr, runs and drives perfect except for the low idle.
Old Apr 21, 2006 | 11:36 AM
Azn Kenny's Avatar
The important thing is that they're all consistant.
Old Apr 21, 2006 | 01:18 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: (LSntegra)
thats what i got in the ls b18a
Old Apr 21, 2006 | 02:51 PM
J.C. ALL STAR's Avatar
make sure the car is fully warmed up and you have the throttle plate fully open when cranking it over.
I made both those mistakes on my DSM when doing the compression test, but my friend said the same as above. "The more important thing is that they are all consistant"
Old Apr 21, 2006 | 03:05 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: did a compression test... (gisserhatch)
The compression gauge can significantly affect the magnitude of the numbers. Consistency in the key.
Old Apr 28, 2006 | 07:07 AM
I would agree that more likely then not, your engine is fine.
Old Apr 28, 2006 | 07:35 AM
thanks, but as far the 100rpm idle Im still stumped
76 camaro car
Apr 20, 2017 04:47 AM
disease0905
Sep 13, 2013 05:04 AM
vtechjunkie
Apr 20, 2010 05:52 AM
GODSPEED33
Dec 22, 2006 06:04 AM
97grnrs
Jul 22, 2006 07:52 PM
