Hesitation when maintaining speed?
Hey guys, recently my car has developed an odd tendancy to bog/hesitate when maintaining speed. If I nudge the gas a bit it usually (but not always) goes away, however if I go WOT, it immediately resumes "normal". I have tried 2 diff ECUs also.
Any ideas?
Thanks!!
Any ideas?
Thanks!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">my car has developed an odd tendancy to bog/hesitate when maintaining speed.</TD></TR></TABLE>
At any particular rpms? Maybe you should have Len plug in his HDS gizmo when you're at Baranco tomolo
Could be a lot of things - bad gas (should go away with the next fillup), clogged fuel filter, dirty air filter (which is why filters are changed in the preventive maintenance schedule), etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">Hey guys, recently my car has developed an odd tendancy to bog/hesitate when maintaining speed. If I nudge the gas a bit it usually (but not always) goes away, however if I go WOT, it immediately resumes "normal". I have tried 2 diff ECUs also.
Any ideas?
Thanks!!</TD></TR></TABLE>
stock ecu? injectors? when was the last time you adjusted timing, replaced spark plugs, wires, rotor, cap
Any ideas?
if everything everyone else mentioned doesnt fix it, then you should look into your o2 sensor
was doing this on my hx with a gsr, and it turned out to be a o2 sensor dieing, later the CEL 41 popped up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">
stock ecu? injectors? when was the last time you adjusted timing, replaced spark plugs, wires, rotor, cap</TD></TR></TABLE>
Does it with both the stock ECU and Hondata ECU. Stock injectors. Timing, plugs and wires were done over this past winter. The rotor and cap I dunno (car has 69k on it)
I actually have a new cap and rotor but no screw, can I reuse the old screw ?
<- nevaR opened up dist cap or rotoR before
I actually have a new cap and rotor but no screw, can I reuse the old screw ?<- nevaR opened up dist cap or rotoR before
I wouldn't hesitate to reuse the screw. If you have an OEM replacement, check the bag becuase IIRC, it should include a new screw. Just be sure you don't strip the screwhead when removing the old rotor button.
Make that 2 votes for O2 sensor. You use it at part throttle, especially constant throttle. WOT it reverts to the fuel tables, and also when changing throttle input it will ignore the o2 sensor for a bit.
What time is it? Time to unpimp... the o2.
-Chris
-Chris
i just found out this problem ..
After swaping my ecu to P28.. it happends when i am in Low throttle position and specially at lower rpm below 4000
when in the traffic. cruising and trying to speed up a bit .. giving a little throttle the car like jumps and it's not smooth.
the power doesnt die out but more like a sudden spike when applying little gas.
69k is way too many miles.. my car would cut of at certain rpm and run really hot and it was 45k miles on rotor.. i don't think the rotor comes with the screw and you have to reuse the old one. i had minor hickups with hondata but not with stock injectors. recently, after switching to open loop and 3barmap sensor i don't have that issue anymore.
</TD></TR></TABLE>69k is way too many miles.. my car would cut of at certain rpm and run really hot and it was 45k miles on rotor.. i don't think the rotor comes with the screw and you have to reuse the old one. i had minor hickups with hondata but not with stock injectors. recently, after switching to open loop and 3barmap sensor i don't have that issue anymore.
Is your O2 sensors! Mine did the same thing. I though it would be the cat, the dizzy, the ignition system. But all it was was the O2 sensor. In my case, it was the primary O2. I went to the junk yard and got me a GS-R primary O2 and it got things back to normal but I've destroyed a perfectly good cat in the process. That one did suck!!!
Make that 4 votes for the primary O2 sensor... mine has had the issue on and off for the past year but I've never done anything about it since it usually goes away and doesnt come back for another month.
Thanks for the helps peoples. Why doesnt the bad O2 throw a code though? I prob look into swapping out the O2 and while Im at it go ahead and change the cap and rotor since I have them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">Thanks for the helps peoples. Why doesnt the bad O2 throw a code though? I prob look into swapping out the O2 and while Im at it go ahead and change the cap and rotor since I have them. </TD></TR></TABLE>
sometimes a lazy o2 looks "good enough" to the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">Update: It was in fact primary O2 sensor. Expo here I come bitches</TD></TR></TABLE>
bring the metal brotha
Thanks for sharing..... I will store that tid bit somewhere.
Which R are you bringing anyway?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">I had the same problem about 3 years ago. I replaced the cap and rotor button and the problem went away.
It happened to my R too. I replace the rotor cap and button. And never had a problem eversince.
</TD></TR></TABLE>It happened to my R too. I replace the rotor cap and button. And never had a problem eversince.
My 97 did the same thing. Checked the o2 sensor graph on the HDS while I was at work and it was going ape chit, so I repl the primary o2 sensor and it fixed the problem as well. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">Thanks for the helps peoples. Why doesnt the bad O2 throw a code though? I prob look into swapping out the O2 and while Im at it go ahead and change the cap and rotor since I have them. </TD></TR></TABLE>
Aslong as it is wilthin specs for the ecu, it will not throw the code. This is called a "lazy" o2 sensor or previous stated.
Travis
Travis
BLUE EH3
Jun 18, 2004 04:59 PM
b18a, car, constant, cruising, hesitates, hesitating, hesitation, integra, maintaining, rsx, s2000, speed, throttle, vehicle
