h22a c98 coupe all motor questoin
ok bro's i was wondering what you guys think of this set up and how much hp i should expect on pump gas.
j-spec h22
wisco 11.5 stand bore pistions
eagle h beam rods
polished crank
supertech nitride coated flat high compression valves
dual valve springs
titanium retaniers
skunk2 stage 2 cams
skunk2 intake manifold
rc 440cc injectores
fuel pressure regulator
unorthodox underdrive alternator and crank pulley set
aem full pump made for up to 600hp
act clutch
msd 6a ignition, blaster coil
fidanze flywheel
Neptune, programing. let me know how much power you think i should get guys thanx
j-spec h22
eagle h beam rods
polished crank
dual valve springs
titanium retaniers
skunk2 stage 2 cams
rc 440cc injectores
act clutch
fidanze flywheel
