Car wont start help please
Old Apr 20, 2006 | 06:50 PM
2DoorBandit's Avatar
Default Car wont start help please
so the other day i purchased a 94 ex with a bad motor in it so i swapp in my rebuit d16z6 in it, went to start it up nothing happened, and now the fuel pump dosent prime and the is no checkengine light whe you turn the key to the on poisitio,n help me please is been so long since i had a car!!!!
Old Apr 20, 2006 | 07:17 PM
Default Re: Car wont start help please (2DoorBandit)
Bump So i Can check stuff tomarrow mouring before work
Old Apr 20, 2006 | 07:19 PM
FalkenSiR's Avatar
1. Previous owner removed the check engine light bulb to hide a problem with car.
2. Check your main relay, fuses, etc...
3. Does it crank? What does it sound like?
Old Apr 20, 2006 | 07:21 PM
EJ8-y8's Avatar
check the little 18 gauge wire to the starter. i beleve its the trigger wire from you ignition switch. i had it fall off on me during a trans swap in my dsm. i m-fed mfself for like a week after i figured out what it was.
Old Apr 20, 2006 | 07:23 PM
Default Re: (EJ8-y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">1. Previous owner removed the check engine light bulb to hide a problem with car.
3. Does it crank? What does it sound like?</TD></TR></TABLE>
the bad motor cranked but it had a bent rod and the cel came on before started doing this today and i checked that wire im think my wire harness is shot and i also swapped ecus for a nother p28 and same thing ahppened
think it could be a relay and if so where are those?
Old Apr 20, 2006 | 07:47 PM
FalkenSiR's Avatar
Default Re: (2DoorBandit)
Relay is right on top of the hood latch. By your feet. stick your hand in there, it's a little 1.5"x4" black box with wires going in and out.
Old Apr 20, 2006 | 08:29 PM
blueshark's Avatar
Check your main fuses! (Under the hood fuse box.)
Old Apr 21, 2006 | 06:03 AM
Default Re: Car wont start help please (blueshark)
i check my fuses will check the realay right now
Old Apr 21, 2006 | 06:22 AM
aquabob89's Avatar
* B A N N E D *
I had a battery go bad, it blew the ecu fuse and fried my harness.
Check all your fuses ignition and ecu. All that start up stuff.
Old Apr 21, 2006 | 11:59 AM
Default Re: Car wont start help please (aquabob89)
fusses are good ecu is good i used it before in my other car ingnition looks good im think it may be the engine harness im gonna take it out and inspect it
jays35
Jun 17, 2014 02:31 PM
92nahatch
Sep 16, 2008 01:05 PM
Leighza
May 29, 2007 08:20 AM
JJ's civic
Apr 30, 2006 03:16 PM
No More Civic
10
Aug 27, 2002 09:35 AM
