water in the taillights
hey guys, I just went to wash my car and when I got home I noticed there is water in the taillights! I took the taillight out, can that red lense be removed? anyone know of any quick way of removing water from the taillights?
thanks
thanks
There is an article you heat up your oven then the seal around the plasic gets all mushy remove it, clean it up. Then use that silcone sealent to reseal it and tada. Make sure that you seal it well otherwise you will have it leak again.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDb18b »</TD></TR><TR><TD CLASS="quote">use a glue gun to seal up the leaks</TD></TR></TABLE>
Do it right. spend the fifteen bucks on the gasket.
Kimo
May 28, 2004 10:05 AM
