strut bar install
Is the strut bar one piece? When I mounted my ITR front strut bar, I preloaded it by pushing down in the center (about 20 pounds of force) while tightening the four mounting bolts. If I did not do that, it rattled. It is a three piece unit.
jack up the car so that more force is put on the strut bar, because you want it to take tension and be tight, because thats the purpose of the strut bar. you wouldnt want it to be loose
