for sale: gsr transmission, gsr gear set w/ synchros and forks, etc.
From: gravity rides everything...everything will fall, se GA/ne FL
for sale:
*no grinds hydro gsr transmission.
-$600 picked up, $680 shipped.
*mint gsr 1-5 gearset with used mint condition complete 1/2, 3/4, and 5/R synchros/sleeve sets and shift forks and shift mechanism, reverse stuff, and hardware.
-$350 picked up
-$200 for just 1-5 gear stacks (no synchros).
*'00 type r 1-5 gearstack. mainshaft and main 3-5, countershaft 1-5. synchros for 1/2, 3/4, and 5/R. all forks, reverse stuff, and shif mechanism.
-$350 picked up with synchros
-$200 just for the gears.
*brand new oem B-series hydro (vtec) 1/2 sleeve set for b16, gsr, itr, ctr...
-$225
*various transmission gears, speed sensor assemblies, internals, and parts...
-pm me
WTB
*outer or complete hydro b series transmission casings.
*busted or grinding hydro ls transmissions.
Modified by not so civic at 12:08 PM 7/26/2006
for sale:
-$350 picked up
-$225
-pm me
WTB
old post not updated...look at the date.
4/20
4/20
I have a 95 LS tranny with a perfect casing. 3rd pops out and grinds when releasing clutch while in gear. all other gears where fine.
Make me an offer.
You will have to pick up if you want it. I'm in ft lauderdale.
Make me an offer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dammit_Dan_954 »</TD></TR><TR><TD CLASS="quote">I have a 95 LS tranny with a perfect casing. 3rd pops out and grinds when releasing clutch while in gear. all other gears where fine.
Make me an offer.
You will have to pick up if you want it. I'm in ft lauderdale.</TD></TR></TABLE>
GSR transmission still for sale?
Make me an offer.
i have two GSR, one '00 B16, one LS, and one jdm H22 M2A4 right now.
*carbon synchros available installed for the hydro b series vtecs.
pm 93_DB2. he is a local buddy, his name is mark...good seller. do you need both rods? i actually have the stabilizer rod/dual bend shifter. i don't have the shift extension rod (bitch pin-bottom of shifter bracket).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapSpec954 »</TD></TR><TR><TD CLASS="quote">DO U HAVE A SHIFT LINKAGE FOR SALE</TD></TR></TABLE>
i have the stabilizer and stock dual bend shifter. i don't have the shift extension rod that bitch pins into the end of the transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peter Shen »</TD></TR><TR><TD CLASS="quote">is your GSR gearset still available?
sent you a pm.
</TD></TR></TABLE>sent you a pm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">
sent you a pm.</TD></TR></TABLE>
thanks alot! my email is peter@e-tuningshop.com
