??????'s about pistons ring
Old Apr 20, 2006 | 12:01 PM
si90rex's Avatar
Default ??????'s about pistons ring
i have a 90 crx si with a D16a6 block and a Y8 head. i smokes really bad. and i losing oil so i i figured my rings are bad so i used some restore (it attempts to seal the rings) but it had very little, if any affect. is there any thing that i could do, so i don't have to rip apart the block.
thanks for any help
Old Apr 20, 2006 | 12:16 PM
strictlyimport's Avatar
Default Re: ??????'s about pistons ring (si90rex)
there isn't much you can do besides rip the motor apart unless you can find another block that is good.
Old Apr 20, 2006 | 12:23 PM
si90rex's Avatar
Default Re: ??????'s about pistons ring (strictlyimport)
that what i figured i have a Y8 block but i'd would like to stick with my A6. the compression is high with the a6.
Old Apr 20, 2006 | 12:31 PM
Well i'd give you mine that i have but it has 206,000 miles on it and it did the same thing. that is why i bought my b16. It will cost less to find an another a6 with good piston rings than if you where to rebuild. There are plenty of a6's out there.
Old Apr 20, 2006 | 12:48 PM
sauceja's Avatar
I have stock a6 pistons, rods, rings that are in decent shape. Not asking much for them make an offer. They are already removed, just waiting on eagle rods for turbo a6/z6 build.
Old Apr 20, 2006 | 01:53 PM
si90rex's Avatar
see there my problem i thought about an ls swap but i just put a in clutch. plus the head is built. yes i get more power out of a b series but i would loss more money because i would be starting over. the bseries would need a clutch, headers the works all over again.
Old Apr 20, 2006 | 01:56 PM
si90rex's Avatar
Default Re: ??????'s about pistons ring (sauceja)
i need just the block i can reuse the pistons and rods but i think the cylinder walls might be to deep of scratchs to just hoen out
Old Apr 20, 2006 | 01:57 PM
si90rex's Avatar
i need just the block i can reuse the pistons and rods but i think the cylinder walls might be to deep of scratchs to just hoen out but then again i could bore out a 1.5 to a 1.6
Old Apr 21, 2006 | 05:34 AM
sauceja's Avatar
Or you could get new sleeves for close to what you will pay for a bore/hone job.
Old Apr 21, 2006 | 08:33 AM
si90rex's Avatar
true i could do that
Txdragon
Engine Machining & Assembly
14
Feb 10, 2018 04:53 AM
freddysEF
May 15, 2009 06:20 PM
Radyjr
May 22, 2008 12:29 PM
97grnrs
Apr 10, 2007 10:34 PM
