my alignment sheet, is this ok?
Old Apr 20, 2006 | 11:50 AM
CRXified's Avatar
Default my alignment sheet, is this ok?
well i got an alignment the other day and the rear bolts to adjust were seized on my car and they didnt wanna snap them. they said it wasnt too far out and i dont know how to read this really, tell me what u think
i know its kinda small, but i hope u guys can make it out
TIA
Old Apr 20, 2006 | 12:52 PM
schardbody's Avatar
looks fine, just toed out a little, dont worry about it, just keep the tires rotated every 3-5k miles or at every oil change and it will be ok
Old Apr 21, 2006 | 04:23 AM
CRXified's Avatar
thanks man, wanna give me some tips on how to read this?
is the actual reading what they did to my car or what it was when i took it in?
Old Apr 21, 2006 | 04:46 AM
rice a roni's Avatar
Default Re: (CRXified)
usually how them alignment rack machines work is that if the readings are in the red then they're way out of specs.
Old Apr 21, 2006 | 06:04 AM
schardbody's Avatar
yeah, the actual is wha its sitting at now, the "saved" is the specs it was at when you brought it in. and the min - max is the specs its needs to be to be considered "in specs" your rear toe is out a little, but i wouldnt worry about it, mine is worse than yours and i dont wear tires.
Old Apr 21, 2006 | 06:27 AM
Ricey McRicerton's Avatar
Default Re: (schardbody)
Looks fine to me. Toe is the big killer of tires, and since you're at 0 on the fronts (which is all I squinted at honestly), you should be okay.
Old Apr 21, 2006 | 07:41 AM
CRXified's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Looks fine to me. Toe is the big killer of tires, and since you're at 0 on the fronts (which is all I squinted at honestly), you should be okay. </TD></TR></TABLE>
haha, thanks man, sorry its so small, maybe u need bifocals
lrcrx90
Suspension & Brakes
Apr 24, 2007 05:26 PM
turnsignalandy
66
May 25, 2006 03:29 PM
cambopheonix56
16
Sep 11, 2005 02:19 PM
B18C5-EH2
Aug 19, 2003 07:57 AM
justininhifi
Jul 3, 2003 06:59 PM
