Aftermarket OBD2 Injectors for 96-01 civic or integra
Old Apr 20, 2006 | 04:31 AM
Power Rev Racing's Avatar
Default Aftermarket OBD2 Injectors for 96-01 civic or integra
Does anyone make a plug and play injector for a OBD2 civic or integra?
For example. Someone has a 2000 civic dx and they want to turbo it, but dont want to cut there wire harness.
what about 0BD2 prelude injectors. Will these work also, or will they cause a problem. I know they work but do they run differently from regular saturated injectors?
Old Apr 20, 2006 | 05:56 AM
notoriousB's Avatar
Default Re: Aftermarket OBD2 Injectors for 96-01 civic or integra (Power Rev Racing)
there is a conversion harness available which will plug into your OBD2 wiring and convert it to an OBD1 socket. there are no OBD2-style aftermarket injectors (at least that I'm aware of)
obd2 lude injectors? what about them? they will work fine but they're only 290cc or so...
Old Apr 20, 2006 | 06:12 AM
Default Re: Aftermarket OBD2 Injectors for 96-01 civic or integra (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">there is a conversion harness available which will plug into your OBD2 wiring and convert it to an OBD1 socket. there are no OBD2-style aftermarket injectors (at least that I'm aware of)
obd2 lude injectors? what about them? they will work fine but they're only 290cc or so...</TD></TR></TABLE>
Well I thought that Prelude injectors were peak and hold style injectors.
Also the only company i know of with aftermaket obd2 injectors is Accel, but they are basically only 10% higher flow than stock.
Old Apr 20, 2006 | 06:14 AM
Also do you know who sells that obd2-obd1 injector jumper harness?
Old Apr 20, 2006 | 06:24 AM
b18bturbo's Avatar
I been selling the obd2 to obd 1 harness for quite some time. The price thoguh is not really cost effective to set of std obd 1 clips that can take 5 mins to wire in.
The convertor clips from cpr are 85.00 a set shipped
EX-T
Jun 21, 2007 05:16 AM
bmanuhutu
Dec 20, 2006 12:49 PM
gunmetal prelude
Mar 25, 2006 08:37 AM
The Poopsmith
Jun 18, 2003 08:50 PM
