jdmshit ef/b series mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBR_15 »</TD></TR><TR><TD CLASS="quote">az race machine, any link to the site or pics of it?</TD></TR></TABLE>
ummm... http://www.azracemachine.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmazm »</TD></TR><TR><TD CLASS="quote">hasport. they are proven to last.
Hell I've been running the Yonaka b-series mounts for 4 years now and no problem. But they are not as bling bling as the hasport/az etc...
</TD></TR></TABLE>Hell I've been running the Yonaka b-series mounts for 4 years now and no problem. But they are not as bling bling as the hasport/az etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. »</TD></TR><TR><TD CLASS="quote">i dont see what the big deal is as long as they are solid polyurethane bilet mounts they should all work the same these are not motors with 500+ft lbs of torque</TD></TR></TABLE>
the difference is: some stuff is made like ****...some isnt...I have seen welds crack/break, holes not drilled in the right place, mounts that just dont fit or hold the engine in bad angles etc...and I have also seen the inserts fall out, crack, etc...
spend an extra few dollars and get ones you know will hold up and work...I did the whole budget thing once...and guess what 9 times out of 10 it ends up costing alot more then doing it right with the right stuff the first time... The Hasport mounts, and linkage is abou the only thing that I havent had some sort of problem with on my car.
+if it was onbly a few dollars than yes not twice the price i could see that but have you seen a set of az mounts in real life they are what i have they are the same thing as the has port mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDCRXNY »</TD></TR><TR><TD CLASS="quote">i think they are all the same </TD></TR></TABLE>
NO YOU ARE WRONG!!!
anyway innovative just came out with there billet mounts & they look so nice a friend just insalled them in a customers car & they went in without a problem
they are like less than $300
NO YOU ARE WRONG!!!
Stoich
16
Aug 14, 2005 07:56 AM
