ITR rear arms on a GSR to fit ITR shocks/springs?
I will be purchasing a ITR suspension minus the rear lower control arms for my 01 GSR.
My question is can I use the shocks and springs from a ITR **without** using the TYPE R rear lower control arms? Will the stock GSR arms work with the ITR shocks/springs front and rear?
Many Thanks,
-Nader
Many Thanks,
-Nader
you cant mix and match the lower arms with struts, if you use the gsr arms, u must use that fork stlye strut, same thing fort eht itr arms/ you can mix asnd match the springs though
Thanks for the information.
How much do the rear lower arms (used) go for? If there fairly expensive, then I may just try and find some used Bilsteins and go for the GC C/O kit.
Thanks.
Thanks.
I've seen them go anywhere from $75 to $100 or slightly more. I wouldn't pay more than $100 shipped, and to me that's still on the high end if you don't need them right away.
check with b18c1_powered_si for them...I'll bet he's got two pair waiting.
i did this to my 01 gsr as well. u dont need the fron lower control arms. u just need the rear. u shouldnt pay more than 75, i paid 60 for them brand new
No, the rear are different. I just put ITR shocks on my hybrid '92 CX Civic. I used Integra Ground Controls and ITR rear LCA's (which you NEED). The rear are different.
Mugen_R
Jul 2, 2002 03:43 AM
