JDM S2K seat swap with DC2 seat parts
Ok so im impatient to get an EG seat pan like eveyone else. So i took apart my GSR seat to see if the DC2 parts would work.
They do but you need to MODIFY the seat a little.
This is what I was using in my GSR. its great but tedious for a daily driver. Plus JDM S2k is so cool
You will need:
17mm socket
14mm socket
12mm socket
Needlenose Pliers
Zipties
Philips Screwdriver (+)
Take the brackets off the S2k Seat and your DC2 seats.
The lever thing that reclines your seat is a two piece thing on the S2k. While the DC2 is sort of one piece and the bracket bolts to teh bottom. Just leave it on for the DC2.
You also need to remove the reclining control bracket. For driver side it is the lefthand side bracket. both the DC2 and the S2K has it bolted to the seat back on the side.
you will need to peel back the seat cover. at the bottom of the seat back (if the seat was in the normal upright position) the seat cover comes together with a sort of plastic clip system. its a pain the ***. you may need to use a screwdriver. (-) head. The S2k seat has a metal ring that you will need to remove.
Now you will need to cut the foam on the DC2 seat to get to the bolts. The S2K you just need to pull the seat cover/leather up a bit to get to the upper bolt.
Remove both bolts from S2k and DC2 seat back.
Here is a comparison of the DC2 bracket and S2K
Also after lookig at the S2K seat brackets, they sit flush and flat to the ground compared to ours that sit at an angle and down.
Now onto the seat bottom of the S2k and the DC2. start to remove the metal rings that holds the seat cover on the seat bottom.
there are 13 total. 4 on each side. three on the front and two in the back.
once you remove the melta rings pull the metal pan out. careful it has some sharp edges
here is a comparison. DC2 on the left and S2K on the right also look at the S2K seat pan. there is a metal support on the side, you are sort of looking right down ontop of it. It is suppsoed to slip into the side bolster and keep it from collapsing when you slide in and out.
NO EG and DC2 Seat pans are NOT the same
here is a pic i grabbed from HT.com of an EG seat pan. see how it looks like the S2K seat pan?
Now you need to remove the metal springs from the DC2 seat pan.
now put the DC2 seat pan into the S2k seat bottom and use small zipties to re tie the seat cover back on.
Also watchout that the side mounting holes for the brackets are not covered by the seat cover.
Put everything back together and put it in your car.
And here is a closeup of the JDM S2K seat inserts. they are an alcantara type cloth.
This was a test to see if DC2 seat parts work or not and they do. Now I will get EG seat parts and put my DC2 seat back together. Then I will have the metal supports fabricated and welded on cause im worried about the seat bolsters.
and for a bit of trivia. The S2K seat pan and sliders/brackets are lighter than DC2 parts. by using DC2 parts you gain three more lbs. each item: seat pan, L bracket and R bracket are all 1 pound lighter than the DC2 versions.
Modified by Solscud007 at 7:36 PM 4/19/2006
Modified by Solscud007 at 10:12 PM 4/19/2006
You will need:
17mm socket
14mm socket
12mm socket
Needlenose Pliers
Zipties
ooh yeah also a little bit of trivia. the seat pans of teh S2K are 1lbs lighter than DC2. also the Seat brackets/sliders each are a pound lighter. so you gain 3 lbs with DC2 parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">Nice work
Your harnesses were mounted very dangerously by the way.
in what way? that is how sparco reccomends. mounted to the back seatbelt mounts.
i think you are thinking of straight vertically down then yes that is bad
</TD></TR></TABLE>in what way? that is how sparco reccomends. mounted to the back seatbelt mounts.
What I'm refering to is the angle of the shoulder harness after they exit the back of the seat. The way you have them the angle is way to steep. If you were in a head on collision the harnesses could easily crush your spine.
proper harness mounting angles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">What I'm refering to is the angle of the shoulder harness after they exit the back of the seat. The way you have them the angle is way to steep. If you were in a head on collision the harnesses could easily crush your spine.
weird I heard differently. From Sparco they said no more than 45 degrees. or soemthing like that.
Lan:
The sparco is getting boring. this is a daily driver car for me and I dont push it due to the fact that it is an old car with a butt load of miles on it. Also my lower back is starting to hurt. didnt used to do that. but also the seat mount base im using is a modified Civic Ek base when i had a civic. it makes the shoulder bolster hit the door panel. so that is also annoying. Plus I think its kidna rare to have JDM S2K seats.
</TD></TR></TABLE>weird I heard differently. From Sparco they said no more than 45 degrees. or soemthing like that.
Lan:
I just put some Momo Buckets in mine, I hated the stock GSR interior. I like your door panels too BTW, I just installed the same ones on my ride
. Edit- I looked at them again, they are not the same
. I just picked up the JDM ones. I like the S2K seat too, I have seen some of your posts before... you have 17" te's too right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">I just put some Momo Buckets in mine, I hated the stock GSR interior. I like your door panels too BTW, I just installed the same ones on my ride
. I just picked up the JDM ones. I like the S2K seat too, I have seen some of your posts before... you have 17" te's too right?</TD></TR></TABLE>
haha yeah i might go JDm one day. But these arent that bad. they are stock black with a little grey lines on them.
Yeah i have tes.
The seat was 350. from hmotorsonline.
. I just picked up the JDM ones. I like the S2K seat too, I have seen some of your posts before... you have 17" te's too right?</TD></TR></TABLE>haha yeah i might go JDm one day. But these arent that bad. they are stock black with a little grey lines on them.
Yeah i have tes.
good technical post.
you may want to try a different server as some images have exceeded there bandwidth. also, a few commas would help with the reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">i like the US s2k seats better.</TD></TR></TABLE>
really> i was slipping and sliding all over the place when i drove my friend's 01 S2K.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 »</TD></TR><TR><TD CLASS="quote">
really> i was slipping and sliding all over the place when i drove my friend's 01 S2K.</TD></TR></TABLE>
I see what you mean, I just think they look better.
gabrielsousa
Jun 11, 2016 11:42 PM
spoon23_JDizM AkA SpOoN20
Apr 15, 2005 07:58 PM
