What does it mean when A50 fuse blows the IG fuse
Old Apr 19, 2006 | 09:38 AM
vtec25's Avatar
Default What does it mean when A50 fuse blows the IG fuse
When A50 the IG
Old Apr 19, 2006 | 09:46 AM
Relic1's Avatar
I tried to guess what you actually meant to ask, but my brain couldn't get there.
how about a little more info or for that matter... some info.
Old Apr 19, 2006 | 10:00 AM
vtec25's Avatar
Default Re: What does it mean when A50 fuse blows the IG fuse (vtec25)
the 50A where it says IG in the engine bay fuse box blew. What could have caused that? and what is IG? is it ignition?
Old Apr 19, 2006 | 11:57 AM
Relic1's Avatar
IG = ignition (ie powered by the key)
it could be a ton of things. What have you changed?
Old Apr 19, 2006 | 12:11 PM
rice a roni's Avatar
Default Re: (Relic1)
blown fuses usually results from a wire or somthing shorting to ground before it gets to the load. stick a 50 amp fuse in, does it blow right away? or does it blow when you try to crank the engine over? i hate intermittent electronic problems...pisses the hell out of me.
Old Apr 19, 2006 | 12:14 PM
civic93@8psi's Avatar
mine did that on my 2000 si i changed it and it hasent happend again in 3 years
Old Apr 19, 2006 | 12:25 PM
GetawayInMoscow's Avatar
Default Re: (civic93@8psi)
50A = 50 amps
IG = ignition
If you don't understand this I dunno if you can replace a fuse.
Old Apr 19, 2006 | 01:36 PM
Schrader's Avatar
Default Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">50A = 50 amps
IG = ignition
If you don't understand this I dunno if you can replace a fuse.</TD></TR></TABLE>
hah.. Thats just mean
Just try Changing the fuse first, and see what happens
Old Apr 19, 2006 | 02:20 PM
vtec25's Avatar
Default Re: (Schrader)
Ok i changed it and problems so far. and i changed the radio 2 days ago.
Old Apr 19, 2006 | 05:01 PM
Default Re: (vtec25)
that might explain it. once i was messing with my cd player in my car and i shorted some wires to ground...i blew a fuse and i got confused as hell because my clock wouldnt work and **** so i checked all my fuses and found that i blew a 7.5 amp.
Old Apr 20, 2006 | 07:35 PM
vtec25's Avatar
Old Apr 21, 2006 | 06:46 PM
vtec25's Avatar
Blew again today
Old Apr 25, 2006 | 03:23 PM
vtec25's Avatar
Blew again today
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
Hanmin
May 16, 2008 02:17 AM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
Hoagieryder
Sep 18, 2005 07:16 AM
TheAutoboxer
Apr 13, 2003 10:40 PM
