what a/c pump to use on h22 into 5th gen
I have a pump in there now but the lines do not fit in the holes. I'm not sure what pump it is. Do I need prelude a/c lines or a different pump?Thanks
What AC pump bracket are you using?
If you have the H22 bracket on there take it off and put your Accord bracket on and everything will bolt up just fine using the Accord pump.
