Suspension & Brakes Theory, alignment, spring rates....
rear passenger side won't lower????
Old Apr 19, 2006 | 06:39 AM
slowhonduh93's Avatar
Default rear passenger side won't lower????
Hey guys I installed my kyb agx struts and neuspeed street lowering springs about 2 weeks ago and my rear passenger side is still looking like it's stock height.... the fronts have about a pinky between the tire and the fender... the rear drivers side has about a finger and a half and the rear passenger side has about 2 and a half fingers... Has anyone run into this problem or now of a solution... any help would be apprieciated... thanks Mike
Old Apr 19, 2006 | 06:53 AM
EJ1 wilcox's Avatar
Default Re: rear passenger side won't lower???? (slowhonduh93)
Do you have a rear sway bar?
Just a thought... if you have an adjustable rear sway bar make sure the endlinks are even.
When I first put my rear sway bar on I accidentally installed one endlink about 1/2" longer than the other and it caused the rear passenger side of the car to be about an inch taller than the other side, even though the coilovers were set at the same height.
Anyways, that was kind of a shot in the dark, but who knows. Something to check at least.
Old Apr 19, 2006 | 08:38 AM
Joon Joon's Avatar
Default Re: rear passenger side won't lower???? (EJ1 wilcox)
make sure that the spring is seated correctly.. could be out of place..
Old Apr 19, 2006 | 09:35 AM
I take it back off and see whats going on with it... hopefully thats the problem... later and thanks Mike
Old Apr 19, 2006 | 09:42 AM
Joon Joon's Avatar
Default Re: (slowhonduh93)
dont really need to take it off.. just raise it up and look then as u lower the car, lower it slow and see if the spring is going into the top hat
Old Apr 19, 2006 | 11:10 AM
roger that.. that's what i meant... hahahaha
auto addict
Jul 6, 2008 12:47 PM
Team Bukkake Sucks!!!
42
Jan 14, 2008 07:05 AM
jfingers8
Mar 30, 2006 05:37 PM
dvp
60
Sep 30, 2005 04:35 PM
eg6madness
May 13, 2002 10:35 PM
