b20 swap question
Old Apr 19, 2006 | 05:04 AM
v-tecleta's Avatar
Default b20 swap question
i am trying to put a b20 swap on my 95 del sol what do i need and how much would i be spending if someone would just be kind enough to list all the things needed and some infos. and if ever i put a b16 head will that be a direct bolt on to the b20 block? t.y.
Old Apr 19, 2006 | 08:15 AM
civicstar's Avatar
Default Re: b20 swap question (project D)
first u need a complete longblock, those usually run around 500-650, then u need a transmission, flywheel,clutch, rear transmission mount. Shift linkage, axels (with intermediate shaft. ECU, depending on if its a change between OBD0-1-2. the long block should already come with a intake manifold and throttle body. you also need some headers.
if u want to go B20 vtec. U will need a Kit. witch has the oil line. then u will need to get your head tapped. and then make sure u get the correct head gasket. i cant remeber but i think it was still an LS. you will need the B16 Manifold and throttle body. then u will need a Vtec ECU. and then u will have to wire Vtec.
Old Apr 19, 2006 | 07:38 PM
v-tecleta's Avatar
Default Re: b20 swap question (civicstar)
whew.. sounds like a lot of work i went to the junk yard and saw a 98 integra i got all the wirings and all the mounts i hope that would save me a couple of buxx.. thanx man..
Eg9502
Feb 15, 2015 09:23 AM
uses0ap
Jun 2, 2008 03:44 AM
AiL45
Nov 14, 2006 01:42 PM
XYU
Oct 31, 2005 03:45 PM
teggytegteg
Jun 6, 2004 10:56 PM
