will 234/60/15 ffit on rotas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">My suggestion is to getting wider rims with a more negative offset than +40.</TD></TR></TABLE>
can you explain to me what offset is? im completley clueless on what offset is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtaaakkkk!!! »</TD></TR><TR><TD CLASS="quote">can you explain to me what offset is? im completley clueless on what offset is.</TD></TR></TABLE>
http://www.tirerack.com/wheels...d=101
That should help.
That should help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtaaakkkk!!! »</TD></TR><TR><TD CLASS="quote">thanks that makes sence
But why would i want a negitive offset of +40? why not 0 offset?</TD></TR></TABLE>
Not a negative offset, a more negative offset compared to +40 so you can have a wide tire without it rubbing on the inside of the fender well. But you won't be able to lower the car.
But why would i want a negitive offset of +40? why not 0 offset?</TD></TR></TABLE>Not a negative offset, a more negative offset compared to +40 so you can have a wide tire without it rubbing on the inside of the fender well. But you won't be able to lower the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Not a negative offset, a more negative offset compared to +40 so you can have a wide tire without it rubbing on the inside of the fender well. But you won't be able to lower the car.</TD></TR></TABLE>
Too much and you will get rubbing on the inside on the fronts when you turn
Why do you want such wide tires anyways? Just get the right size, probably 195/50-15 or 195/55-15 depending on your car, and concentrate on getting better tires. With a give budget you can either get really good regular tires or poor quality wide tires. You will get much more performance out of good quality tires than wide tires.
If you want a wide wheel base, just get extended studs and put your steelies on backwards. JK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">Just get the right size, probably 195/50-15 or 195/55-15 depending on your car, and concentrate on getting better tires. With a give budget you can either get really good regular tires or poor quality wide tires. You will get much more performance out of good quality tires than wide tires.</TD></TR></TABLE>
Change Me
Honda Civic (2001 - 2005)
Apr 14, 2007 07:16 PM
AnDThEnWuT
Feb 27, 2006 04:53 PM
90teg
15
Nov 3, 2005 07:25 AM
