Tokiko Illumina shocks/Ground Control Coilovers on 93 Accord. Good shock settings?
Old Apr 7, 2002 | 03:04 PM
se93's Avatar
Default Tokiko Illumina shocks/Ground Control Coilovers on 93 Accord. Good shock settings?
Anyone running this setup in their 4th generation accord? I will be using the Ground Control Street Setup Coilovers with Tokiko Illumina shocks. What are good street setting for the Illumina shocks?
Thanks,
Mark
Old Apr 7, 2002 | 03:44 PM
RJonathan's Avatar
Default Re: Tokiko Illumina shocks/Ground Control Coilovers on 93 Accord. Good shock settings? (se93)
4 for the Rear and 3 for the Front if its to soft then 5 for Rear 4 For Front. This is my opinion.
Old Apr 7, 2002 | 05:38 PM
se93's Avatar
Default Re: Tokiko Illumina shocks/Ground Control Coilovers on 93 Accord. Good shock settings? (RJonathan)
So, is this the general guideline? Should it always be a bit stiffer in the back than the front?
Mark
Old Apr 7, 2002 | 06:27 PM
RJonathan's Avatar
I think the rear should be stiffer because you already have the motor in the front to damp down your front. Well this is only my opinion if someone can correct me on this if am wrong. Or just adjust it and drive around and see which setting you like the best. Thats the best I can say.
skynyrd006
Jun 12, 2006 05:00 PM
imports
Nov 26, 2002 11:14 AM
Lsubball99
Feb 28, 2002 01:44 PM
