Pulling Transmission, LS swapped hatch, Quick ?
Old Apr 18, 2006 | 10:00 PM
Nisif's Avatar
Default Pulling Transmission, LS swapped hatch, Quick ?
For those that have pulled the tranny on your b-series swapped EF, Did you have to take off the rear motor mount bracket off of the back of the block in order to take the tranny off? Looks like a PIA, considering the lack of clearance b/w the rear x-member and the tranny housing.
Old Apr 19, 2006 | 12:43 AM
Malgerus's Avatar
Default Re: Pulling Transmission, LS swapped hatch, Quick ? (Nisif)
Nope, you don't have to.
Just pull off the tranny mount
Old Apr 19, 2006 | 04:21 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nisif &raquo;</TD></TR><TR><TD CLASS="quote">Looks like a PIA, considering the lack of clearance b/w the rear x-member and the tranny housing.</TD></TR></TABLE>
This can be dealt with quite easily by just rotating the differential down. This produces better clearance with the rear crossmember.
Old Apr 19, 2006 | 07:25 AM
type Gendy's Avatar
Default Re: Pulling Transmission, LS swapped hatch, Quick ? (StorminMatt)
so u dont actually lower the motor at all??
Old Apr 19, 2006 | 11:32 PM
Default Re: Pulling Transmission, LS swapped hatch, Quick ? (type Gendy)
You only need to lower the passenger side enough so that the tail of the transmission clears the frame rail.
truplayaz24
Welding / Fabrication
14
Oct 17, 2007 10:02 AM
strictly.business
Apr 20, 2006 05:25 PM
integra3586
Feb 15, 2006 09:48 AM
comptechgsr
May 19, 2002 03:02 AM
