Help Engin cant start up
Old Apr 18, 2006 | 07:02 PM
ILIKEJDMX999's Avatar
Default Help Engin cant start up
hi, every one, i have a problem. so i need some help from you guys.
i just bought a used 3000 gt couple days a ago, the previous owner had some kinda speacker installed before, he removed it before sell to me. last night i was arrangeing the wires in back, i think the postive eletric wire and negative eletric wire hit each other, and the sparkled, and then my engin stoped. i tried to turn it on, but it acts it is out of eletric, cant start up. i tried to conect the battery with other car, but still doesnot work. do you guys have any idea about it, let me know. thank you very much!!!
Old Apr 18, 2006 | 08:07 PM
Miracle's Avatar
Default Re: Help Engin cant start up (ILIKEJDMX999)
shorted out the electrical circut and blew a fuse. more than likely blew the main starter relay fuse. Are you getting ANY power at all when you turn the ignition key on. If so its probably just the starter relay/fuse.
Old Apr 19, 2006 | 06:15 AM
Default Re: Help Engin cant start up (Red7thGen_ex)
it is getting some power, but just wont ignited
Do you know where can i find the starter fuse? and is possible to do it by ourself?
Thank you
Old Apr 19, 2006 | 06:33 AM
Miracle's Avatar
sould be in the underhood fuse panel. I used to have a Eclipse GS-t but i dont know how much of it is the same as to location, but pull the cover off and on the label, it will show you where on the fuse panel its at.
Colby Schwedes
Honda Ruckus and Scooters
May 31, 2019 06:02 PM
Mason Edmison
Oct 22, 2017 09:19 AM
azandford
10
Jul 1, 2017 05:39 PM
BigDaddyRich
Aug 14, 2005 12:15 PM
MeanGreenEG9
May 6, 2003 05:02 AM
