Having problems with left rear window
I've got a 2000 accord LX 4 cyl. for the past month and a half I've been having problems with the left rear window going up and down. Sometimes it works other times I can hear a click but the window just doesn't move.
I went back to the body shop I took it to a year ago when I had my accident in which the entire back end of my car was crushed in. He recommended WD-40. I used it but the problem is still there. I don't really trust the guy and was wondering what the problem might be so I can fix it myself.
Thanks guys!
Thanks guys!
take off the door panel, and remove the window, regulator, and motor
i bet if you look at the gears (teeth) on teh regulator, a couple of them are starting to grind off, that explains the click.
its probably not that bad right now, since sometimes it will get past that "dead" spot, but eventually it will just wear out and you will have to pull the window past that point.
(i speak from experience on that)
if its not that, make sure the window is on track when you reinstall it, and check the motor.
if all else fails, its probably the switch or wiring shorting out.
