NUT/STUD JUST SPIN!!!! Tie Rod - Easy fix To Get The Bolt To Thread?
Old Apr 18, 2006 | 05:57 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default NUT/STUD JUST SPIN!!!! Tie Rod - Easy fix To Get The Bolt To Thread?
No idea how this happenned, I dont know if something broke sometime during the continuous assembly and reassembly but the nut and stud that holds the tie rod to the tire assembly just spins up inside the tierod
The nut wont back off or come up and theres such a small ammount of thread that I cant grip it with a set of vice grips
I tried with a small set of vice grips but cant hold it enough to spin the nut on or off
Has anyone ever had this happen?, The tie rod is basically new, maybe 1 year old I believe but the stud just spins, I dont get how it attaches up inside the tie rod, can something break there?
The nut is on by probably 7 threads, needs maybe 11-12 more to make it up there
Need to know what tricks there are to get this **** up there
Old Apr 18, 2006 | 06:04 PM
BlueCrxNC's Avatar
It's just a ball joint with nothing to 'break'. It will continue to spin as you've seized the nut onto the stud... have to cut it off. Try dremel/cutoff wheel. Then clean/chase the threads of the stud and get a new nut or just buy a whole new Tie Rod end.
Old Apr 18, 2006 | 07:01 PM
SIXTY's Avatar
Default Re: (BlueCrxNC)
Try to put some pressure on it. Like step on it, or try to "twist" it to one side. This always happens to me because when i am whacking the fuCc out of it i miss sometimes and hit the threads. Good luck.
Old Apr 18, 2006 | 07:09 PM
fourthgenhatchB17's Avatar
Default Re: (sixty-seven point six)
Jam a pickle fork in there and impact the bitch off. Then go buy a new tie rod.
Old Apr 18, 2006 | 07:31 PM
PINKS's Avatar
Cant buy a new one, need this car running
Glowicki
14
Mar 14, 2014 06:58 AM
LOC714
Nov 14, 2009 11:30 PM
MenaceDee
10
Mar 7, 2008 07:23 PM
PINKS
Apr 19, 2006 08:16 AM
zccr-xsi
Sep 25, 2005 06:24 AM
