Where can i buy gears for my 91 manual transmission?
I am in the middle of rebuilding my 91 integra manual transmission. I disassembled it and found that my second gear and first/second gear slider need to be replaced. I ordered my rebuild kit from rockland gear (rings, bearings, seals but they do not sell hard parts) I called up my local Acura dealership and they were able to order me the 1/2 slider but they said that acura (honda america) no longer stocks the gears individually. Does anyone know of a company that makes stock ratio gears for a 91 integra?
Thank you,
-Tim
Thank you,
-Tim
Try this site:
http://www.acuraoemparts.com/delray/jsp/home.jsp
I've had a lot of luck with it. Good luck!
I have 2 91 trannys both have second gears that are slightly damaged, they would work, but im looking to replace them, not dick around w/ damaged parts
i called gear-speed and they are looking into it for me
I might just be stuck putting one of my old ones back in w/ a new syncro and slider.... and praying everytime i shift into 2nd gear....
Gear-speed was a no go, i also tried ats and OS gikon and they both only do hydro transmissions...
michael-crxsi
May 10, 2010 06:57 PM
dateg91
Jan 28, 2007 05:27 PM
