acg fuse blowing
Old Apr 18, 2006 | 04:01 PM
KrispyKreme's Avatar
Default acg fuse blowing
well, i crank up my car to leave for work, get about 20 feet down the road and my car dies. come to find out the acg fuse keeps popping as soon as i turn the key on. before this happened my blinkers werent working at all, could it be related???any help?
Old Apr 22, 2006 | 04:50 AM
Default Re: acg fuse blowing (KrispyKreme)
bump for some help
Old Apr 26, 2006 | 06:07 AM
i need some ***....istance
Old Apr 26, 2006 | 07:21 AM
nocturnaldragon's Avatar
Check your wiring for a short somewhere, its propably going to be a place where the wires are rubbing against a piece of metal because its a slow burn and not instant where it dosent allways make contact or its not a big short so it takes a while to blow the fuse. I would check under the dash first becase you said your having trouble with the blinkers too
Old Apr 26, 2006 | 12:11 PM
Default Re: acg fuse blowing (nocturnaldragon)
yeah i just bought the wiring harness for the gauge cluster and radio and all that from a guy on here bc those wires are all hacked up so im hoping that will fix it as soon as it gets here i will try it out....thanks bro
Old May 2, 2006 | 11:24 AM
replaced old hacked up harness for gauge cluster/radio, still popping fuse....
Old May 2, 2006 | 12:36 PM
ZipTieGUy's Avatar
wt fis ACG fuse. check your helms for what **** is in the circuit. then go on from there
Old May 2, 2006 | 10:57 PM
Default Re: (ZipTieGUy)
i already did,
srs
vss
alternator
eld (wut is eld?)
cruise control main switch and unit
pgmfi main relay
gauge assembly
Modified by KrispyKreme at 7:56 AM 5/5/2006
Old May 2, 2006 | 10:58 PM
Default Re: (KrispyKreme)
a friend of mine thot it might be my ecu so i tried one of his and still pops the fuse
Old May 5, 2006 | 04:57 AM
i'm stumped man, i guess i will check out the cruise control **** cuz that hasn't worked since i've owned the car....
Old Jun 1, 2006 | 05:15 PM
ace4nwk's Avatar
sorry to bring this back up, but did u ever fix the problem??? I'm having the same issue and I cant figure it out!!!! Any assistance is greatly apprieciated. Thanks
Old Jun 2, 2006 | 05:29 AM
ace4nwk's Avatar
Default Re: (ace4nwk)
bump, I really need some help with this!! Cant afford to pay for a tow to my macanic 40 miles away!!!!! any help would be greatly appriciated.
9sihatch3
Jul 31, 2006 10:51 AM
STN_Pat
Jul 22, 2006 05:46 PM
LsNrG
Audio / Security / Video
Dec 10, 2004 05:24 PM
rizen
Dec 21, 2003 09:48 AM
Si_Power
Jun 23, 2003 08:12 AM
