H&R Springs on ebay coilovers? would it work?
Old Apr 18, 2006 | 02:36 PM
nk2k2's Avatar
Default H&R Springs on ebay coilovers? would it work?
hey guys
while i was sitting in my marketing class, i was thinking to myself is it possible to buy something like H&R sport springs and also buy some cheap-o coilovers on ebay and replace the ebay springs with the H&R springs. I think it would work but i don't risk breaking anything or expletiving anything up. so to all you suspension gurus, does it work? thanks.
Old Apr 18, 2006 | 05:05 PM
nk2k2's Avatar
Default Re: H&R Springs on ebay coilovers? would it work? (4g4d)
so no one knows if this is going to work or not? bump.
Old Apr 18, 2006 | 05:17 PM
Outsane's Avatar
no reason to use H & R Springs with coil overs..
Unless you want a way to raise the car..
I'm not sure what your trying to accomplish by using a spring designed for a full shock on a coil over system..
the bottom of the H&R springs are cut to fit into the bottom of the shock OEM style perch..
where the cheap coil over perches will be flat to accomadate the flat bottom of the coil over spring.
901roller
Feb 4, 2010 09:25 AM
oilguzzler
Oct 13, 2006 03:36 PM
Dan Fizzle
Suspension & Brakes
Jul 26, 2006 12:59 AM
nk2k2
Suspension & Brakes
Apr 18, 2006 05:53 PM
MooreBoost
Jul 6, 2003 10:27 AM
