Noise from wheels?
I have a loud noise when i drive the car 35 mph and up. But when i turn right the noise disappears. I think that my wheel bearings are doing this. If yes, how can i find which bearing is damaged? Otherwise, what can be causing this noise?
Thank's
Modified by Simonak15 at 3:53 PM 4/18/2006
Thank's
if it sounds like a whirring noise it is probably your wheel bearing. if it goes away when you turn right then it is on your right side. to check if they are bad jack your car up and shake the tire to see if it moves.(not positive on how this is done but its what i heard.) if it moves you need new bearings. hope that helps
bambbrose
Oct 11, 2015 08:01 AM
