ITR sway bar on a CIVIC
Old Apr 18, 2006 | 01:01 PM
SpoonKid's Avatar
Default ITR sway bar on a CIVIC
I will be using a ITR 22mm sway bar on my 99 civic hatch with omni power control arms. im also going to be using a ASR subframe kit.
can i use the itr end links that come with the sway bar with the omni LCA or do i need to get some sir endlinks?
some help would be great
thanks
Modified by SpoonKid at 2:56 PM 4/18/2006
Old Apr 18, 2006 | 01:06 PM
ek4d00r's Avatar
Default Re: ITR sway bar on a CIVIC (SpoonKid)
youll need the SiR since youre in canada. you should be able to purchase the endlinks from ASR too if you are buying direct
wing
Dec 23, 2006 08:12 AM
fastfu
Jun 8, 2004 04:02 AM
dgdarien
10
Mar 30, 2003 01:09 PM
kungfuSiR
Feb 17, 2002 11:00 AM
