anyone have problems with sticky calipers on track?
after about 5 mins of really hard driving/braking my driver's rear caliper stuck and was smoking and what not so i took a break
strange...... after about 15 mins when i took the break everything was fine brakes seemed normal and could easily push the car around
does this seem common at all for this only to happen after braking hard alot? im assuming no
does this sound like i should replace the caliper? i mean its stupid cus it works perfect everyday under normal driving
--chris
--chris
is that a guarenteed fix...... or somethin to try?............ not tryin to be a smart *** i just need to know if i should keep a close eye on it still or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 »</TD></TR><TR><TD CLASS="quote">is that a guarenteed fix...... or somethin to try?............ not tryin to be a smart *** i just need to know if i should keep a close eye on it still or not</TD></TR></TABLE>
He is implying a suggestion. Check both calipers and brake components.
You could also try a brake fluid flush. Good luck.
rickytz7111
Oct 5, 2008 09:27 AM
